Bosch Fridge Freezer – Handles Breaking !!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch Fridge Freezer – Handles Breaking !!
  • #10061
    We have a Bosch Fridge Freezer Model No KKU3301Gb.
    The handles to both Fridge and Freezer Depts have cracked
    and are now virtually falling off.
    I can see that the fridge compartment handles are
    essentially a ” plastic plate” that has been screwed into the door.
    Therefore it should be easy to replace.
    The handle to the freezer compartment looks like it has been molded on to the top part of of the freezer door. THerefore it apperas as if its a solid
    integral part of the door and hence not a “spare part”. I really do not want to have to replace the whole door !!!
    Can anyone help with:
    Where can I can a spare handle for the fridge compartment.
    Is it possible to get a spare for the freezer compartment ??
    Regards
    ARK
    #138113
    BSH-MAN
    Re: Bosch Fridge Freezer – Handles Breaking !!
    The freezer door handle is the same as the fridge one. The screw heads will have a little plastic cap on them. 😉
    Is it a kku3301gb/01 or kku3301gb/05? As the part number differs, but I suspect they may supersede to the same number.
    Look here.
    http://www.bshappliancecare.com/Bosch/boschspares.html
    #138114
    litlor
    bosch door handle you want Pt number 096109 £5.82+vat & P&P
    #138115
    Model No KKU3301Gb.
    Thanks for all the help.
    #138116
    gegsy
    kku3310gb/01 has frz handle 096109 @ £4.95 GBP
    kku3310gb/05 has frz handle 096110 @ £7.97 GBP
    NEB
    uv light makes the plastic brittle
