Bosch fridge-freezer KGE7005/02 compressor fault comand
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch fridge-freezer KGE7005/02 compressor fault comand
  • #21689
    Bosch Exclusiv type KGEE31A, after some minute(after power-up) compressor is starts but is cutting down few seconds after and after another few seconds up and so on…
    I verify also compressor on direct connected…is ok… temperature is readed ok also. Advice…
    #192172
    gegsy
    Re: Bosch fridge-freezer KGE7005/02 compressor fault comand
    On past experience, it is usually the PCB thats is plugged inhorizontally behind top fascia. P/no – 263781.
    On a rare occasion you may have a faulty compresser 😥
    Thanks Greg, I did guess that.
    I have taking at home PCB to see what’s dead in it.
    #192174
    After removing condens residual from PCB and resoldered cold contacts it works for three days OK. This morning I found him in alarm condition with 18’C inside both compartments.
    Can any help me with electric diagram & correspondence between temperature=sensor resistance?
    #192175
    gegsy
    Just replace the PCB, job done 8)
    Costumer doesn’t want to pay new one. He wants to try repairing.
    #192177
    gegsy
    I don’t think thats recommended, although you could look for 2 black diodes on that module that look like they have scorched the PCB board below them, and replace them. Before you ask I have no idea what type/ value they are 😀
    Yes they are two 12 Volts Zenner diodes. It looks they are OK. Under them on the oder side is one 16Volts (SOT223 cases) is schoching PCB. I will change that three diodes. But I need electric diagram and value of those three sensors in order to check at home PCB(to simulate fridge enviromment)
