Bosch Fridge freezer – KGV3105 – fridge/freezer warm
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Fridge freezer – KGV3105 – fridge/freezer warm
  • #18298
    walnut
    I think this requires the bypass thermister repair but after reading through previous posts I’am confussed as to which wires to short.
    The connector is a four wire job, 2x brown, 2 x blue.
    Does anyone know of hand which two need shorting to bypass to thermistor?
    Any help gratefully received.
    #178498
    gegsy
    Re: Bosch Fridge freezer – KGV3105 – fridge/freezer warm
    Hi Walnut
    What are the symptoms and the full enr number please.
    walnut
    Hello,
    Plug the fridge in and it cools down to temp, stops and defrosts.
    the compressor does not start back up after defrost – 24hrs.
    If you switch power off and back on compressor kicks back in.
    E-NR KGV3120GB/01
    F. D. 7905/25029
    KGV3105
    90221133
    Regards
    Walnut
    #178500
    gegsy
    NTC failure for sure. I will have to look for mod sheet to be sure for you.
    BTW what has KGV3105 got to do with KGV3120 ?? Always get full enr off appliance.
    gegsy
    If you locate the plug connector you mentioned 2 blue 2 brown.
    If you then short out blue (common) with dark brown that should sort it out 😉
    walnut
    Cheers
