Bosch fridge freezer module?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch fridge freezer module?
  • #36006
    allan
    Hi i have been to 2 of these machines, (Bosch kgv3120gb/01) both with the same fault, Dead! but when the module/ control board is unpluged and reinstalled it works, until it gets cold enough, cuts out then does not come back on, i suspect the mod is at fault, first customer could not wait as it was out of stock, but now they are available again this customer wants it done, is this a common fault? and is there any other known probs that could cause this?
    Thanks Allan
    #249113
    smartin
    Re: Bosch fridge freezer module?
    if its the the 1 im thinking of,has it got a small plug on the on the right end of the module with 3 or 4 brown & blue small wires coming out then there is a modification to bypass internal fuse im sure someone else will have the mod sheet in pdf smartin
    #249114
    gegsy
    You have mail Allan 😉
    allan
    Thanks thats realy helpful 😀
    #249116
    allan
    ahh, forgot to change my email address its now allanwalker@adbrown.gotadsl.co.uk bit of a mouthful but its a long storey
    Thanks allan 😳
    #249117
    gegsy
    No problem, make sure you update your profile 😉
    allan
    Have done, thanks again 😆
    #249119
    allan
    Hi Greg, no mail so far?
    Thanks Allan
    #249120
    gegsy
    Re sent 😉
    Simon46
    It is a known fault and cured by a butt connector. Type model number into the search facility its a wonderful thing 😀 .
    S.
    #249122
    allan
    Thanks Allan
    #249123
    gegsy
    Best check your spam folder then 😉
