Re: Bosch fridge freezer problem
There is a back plate in the freezer behind which is the fan and evaporator,these can get blocked by frost.
If you aren’t able to remove the back plate then 48 hours of defrost is required ie,empty,switched off with door open.
If you can remove it use a hair dryer to defrost,no sharp or metal objects and switch off at mains.
There are also a couple of sensors which could be problem,you can check if you have the abilty and equipment required.
