My Bosch KKU3301 fridge freezer has recently developed a problem. On the regular setting the freezer will rise above the highest recommended temperature (-18), causing the alarm to sound. however, if I put it on Superfreeze, it works properly, maintaining the set temperature.
The problem began shortly after moving the fridge about a metre while decorating.
Is permanently running the superfreeze function an expensive and eco-unfriendly compromise solution, if fixing the basic problem is costly? This is a frost-free model, late 1990s.
Thanks.
