Bosch fridge hinges
  • #30557
    mic
    I obtained some hinges for a Bosch Freezer GUL1201GB using the part number off their web site but when I tried to fit them they appeared too small, the holes didn’t line up with those on the appliance. I tried to adjust the fitting so they would fit the door but then they didn’t line up on the appliance. They also don’t look exactly the same having an extra metal bracket at 90 degrees which the original didn’t have.
    Can anyone help as bosch aren’t being much
    #227632
    gegsy
    Re: Bosch fridge hinges
    Do you have the rest of the numbers after the GB/?? please
    Also the part numbers of the hinges you were supplied with. 🙂
    mic
    Hi Greg
    there are no numbers after gb on appliance, but on BSH Appliance care site there are two versons both of which use part 489424.
    Thanks for your help
