Bosch Fridge KIV3235
  • #21652
    Clarkie
    We have just moved and have inherited a Bosch built-in Fridge with freezer compartment (KIV3235) with the kitchen. The freezer door appears to be broken although it will shut if pushed. The bottom of the fridge does not seem cold enough, in fact we have had some food going off very quickly.
    Can anyone please advise on the following?:
    1) Any idea how old the fridge may be?
    2) Any solution to the ‘warm’ fridge?
    3) We don’t have a warranty, so idea of what a repair may cost and who could do it?
    #192028
    Simon46
    Re: Bosch Fridge KIV3235
    The usual fault with the freezer compartment door is the handle breaks not allowing the door to stay closed. Does the fridge run all the time or does it have periods of rest? also the full ENR number would help.
    Regards
    Simon
    #192029
    Clarkie
    Hi Simon,
    The ENR no. is KIV3235GB/42.
    The freezer door handle is partially broken, but does appear to seal shut when pushed.
    The fridge runs very quietly, so I can’t tell if it has periods of rest.
    It’s difficult to know whether to get someone in to look at it, or if it’s more realistic just to invest in a new model.
    #192030
    Simon46
    ok on rear wall do you see ice then condensation? or is there permanent ice.
    Regards
    Simon
    #192031
    Clarkie
    There is ice on whole rear wall of freezer compartment, but just condensation on the rear wall of the fridge area.
    #192032
    Simon46
    It could either be thermostat or system fault. Repairs@ for an engineer to confirm.
    Regards
    Simon
