Bosch – Fridge not cooling, freezer working fine
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch – Fridge not cooling, freezer working fine
  • #95900
    mike k
    I have a Bosch Fridge Freezer, approx 2-3yrs old. Model KGH34X44GB. The freezer compartment is working perfectly, however the fridge compartment is now room temperature and not cooling, Lights etc in Fridge work ok, Any suggestions as to the root cause of the issue – is this something I could repair easily myself or would i need a service tech? Approx cost of a repair? Appreciate any help/advice.
    Tks,
    #461641
    a lot of modern self defrosting fridge freezers cool the fridge by ducting cold air from the freezer. if these ducts get iced up the fridge stops working
    before you do anything switch off with doors open for 2 days and do a total defrost. then see what happens from there
    mike k
    Thanks Dave – did that already as the freezer was quite iced up – but it did not resolve thes issue.
    Mike
