bosch fridge to warm
  • #45419
    briggs
    hello i have got a bosch f/f it is a kgu 32161gb/02 the it has had a freezer fan fitted because it was over frosting but the fridge part after 2 weeks is to warm the repair man said that i will probably need a circuit board what doe you think can i bypass this or should i just get a knew fridge freezer
    wife said if knew one then has to be silver frost free 60cmw 185cmh 60-68cmd got any ideas
    thanks
    #285618
    spimps
    Re: bosch fridge to warm
    New control pcb will set you back £120,if the fridge is too warm it’s likely that the evaporator is over frosting again which will prevent cold air getting to fridge,may be worth checking out defrost heater,defrost drain and sensors which are the more likel cause.
