Bosch Fridge too warm.
  • #24264
    magpie51
    Hello. We have a bosch fridge. Apx 4 years old I think. I have the manual but the only model info I can see is on the front top right of the fridge “Bosch economic”.
    The problem is it seems to be getting too warm inside before it starts up. We bought a fridge thermometer (DIGITAL). We put the sensor at the top left inside and it seems to reach 10 degrees C before the fridge starts up. When it does start up it drops back down to apx 3 degrees c.
    The back plate inside ices up which i think is correct and then drains out (its not blocked) to evaporate in the dish.
    Do you think its the thermostat?
    If so where should I stick it (polite answers only please)
    If anyone could help even with where to find a specific model number i’d be grateful.
    #201358
    Re: Bosch Fridge too warm.
    First thing to do, to give the fridge lads a chance, is find the model number. Pull the salad bins and have a look on the fridge walls. There’s a label. The model number will generally start “K——“.
    magpie51
    Ace thankyou exactly where you said.
    FD8102 002771
    KTR1670GB / 45FD8102 002771
    I think its the KTR one.
    Many thanks Simon
    #201360
    gegsy
    Hi Simon
    The back should ice up app 3/4 way down and then periodicaly will melt and start all over again, thats its normal cycle.
    Is this appliance standing free? to the effect that its not under a work top or next to a heat source as this will drastically effect its operation an may cause permanent damage.
    magpie51
    Its free standing.
    There is space at the back front (obviously and the right side facing.
    On the left stand a freezer.
    I have read on the forums about melting draining and refreezing but the temperature seems too warm inside apx 10 degrees c before the motor kicks in and goes down again.
    Thanks Simon
    #201362
    gegsy
    If it takes a while to come back on but when it does finally activate it reaches acceptable temperature, then it sounds to me like the thermostat.
    If this part is required its number is 170459 app £21 + charges available from spares@ukwhitegoods.co.uk
    Un plug appliance before attempting any repair :plug:
    magpie51
    Yes the temperature is correct once its settled down. I think ill give the thermostat a go its cheaper than a new fridge.
    Thankyou for your help and Very Very fast response.
    Kind regards Simon
    #201364
    gegsy
    You very welcome Simon and good luck.
    magpie51
    One other thing I forgot. Could you tell me where the thermostat is located. Ive changed a thermostat in our tumble drier ( what a job that was) but ive not had the luck to have to dismantle the fridge Until NOW.
    Many thanks Simon
    #201366
    gegsy
    Hi R
    Right hand side of fridge inner wall with light unit. It can be a fiddle to change 🙂 Take your time.
    If in any doubt feel free to use the engineer link below. 😀
