Bosch gas hob ignition switch knob replacement?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch gas hob ignition switch knob replacement?
  • #11842
    I’ve got an old model (at least 10 years old) Bosch fitted gas hob with a separate ignition switch. I don’t know the ENR no. (lost the booklet)
    The rubber knob of the ignition switch has worn out and we’ve removed it. The ignition switch is still working fine.
    So, is there someway to find the ENR no? Is there somewhere online that I can browse old models to find it? Can I locate it without disprupting the hob?
    Or, is the rubber knob fairly standard and can I buy one from somewhere?
    The hob is a 4-burner white, with the 4 burner controls and ignition switch down the side. The original know was grey rubber
    hope you can help, many thanks
    Sue
    #146878
    Del
    Re: Bosch gas hob ignition switch knob replacement?
    Hi Sue,
    Is it possible to look at the hob from underneath as there should be a sticker on it that gives the E-NR and FD numbers which are essential
    before we can find a part no for you.
    Cheers
    Del
