Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch Gas Hob Ignitor Not Working
- This topic has 5 replies, 4 voices, and was last updated 14 years, 1 month ago by
pmac.
February 24, 2012 at 9:20 pm #68094
pmac
ParticipantHi all, I have a Bosch 5 burner gas hob, and the ignitors have stopped working on all of the burners. It is the type where you push down the regulator to operate the ignitors, but when you push it down you get no clicking or any sign of life. I have checked that all of the electrodes are clean and clear, and that that the 230v supply is live and getting to the hob. You can light the burners with a lighter, and they remain alight, so I assume the thermocouplers are working correctly. Is there a central spark generator in the hob that I can replace, or any other common fault that it could be?
The only numbers I can find on the hob are on the plate on the underside of the hob, they are as follows:
E-Nr PCL785FGB /07
FD 8602/00255
Type HSE-7FB4W30 CE-99BM748
If there are any parts I can replace, any pointers of what parts I need, or any help at all, will be greatly appreciated.Many Thanks in Advance Paul.
February 25, 2012 at 2:32 am #369559admin
KeymasterBosch Gas Hob Ignitor Not Working
Looks like the ignition generator has failed.
Bryan
February 25, 2012 at 7:59 am #369560pmac
ParticipantRe: Bosch Gas Hob Ignitor Not Working
Thanks Bryan, any ideas where I can get one from, are they unique to that model or do Bosch do a generic one?
I have searched for one on the Ukwhitegoods site, but have had no luck finding one. Can it be repaired, or is it time for a new hob?
Thanks Again Paul.February 25, 2012 at 8:39 am #369561Martin
pmac wrote:but have had no luck finding one.
Try clicking HERE 😉
February 25, 2012 at 7:30 pm #369562pmac
Thanks for the help and advice guys, I have ordered one, it will be with me next week, ready for a mate of mine who works for gas board to fit.
This is a fantastic forum, that has got me out of trouble several times, I would like to thank you all, and keep up the good work.
Paul (pmac)September 16, 2012 at 9:25 am #369563mossy1283
Just out of interest did this ignition transformer work? I have got the same problem with my hob too which is the same model.
