Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch Gas Hob not lighting
- This topic has 10 replies, 4 voices, and was last updated 13 years, 11 months ago by
daveg1980.
April 18, 2012 at 1:41 pm #69015
daveg1980
ParticipantHi,
I have a bosch oven with 4 gas hobs, one of them does not light up, or click to ignite. The others work fine. I have tried cleaning the hob etc.
Any ideas?
Thanks,
DaveApril 18, 2012 at 2:44 pm #373433don
ModeratorRe: Bosch Gas Hob not lighting
Moved you the cooking forum.
The ENR number would also help the guys to bve able to help you.
Don
April 19, 2012 at 8:01 am #373434daveg1980
ParticipantRe: Bosch Gas Hob not lighting
Thanks Don, a total newbie to this site.
I will dig out the ENR tonight.Many thanks,
DaveApril 21, 2012 at 5:12 pm #373435daveg1980
Got it – hbn2850gb
April 22, 2012 at 4:14 pm #373436Jazzmeister
Would guess at a broken igniton wire to that burner OR a broken/damages ignition unit. *** Please note*** you would have to strip the appliance to find this out, being a gas hob I would advise you to get a gas safe domestic appliance engineer to have a look for you.
Jazz
April 22, 2012 at 9:00 pm #373437nomadPaul
daveg1980 wrote:Got it – hbn2850gb
Dave , i believe this is your oven model number ! I’m guessing you have a Bosch oven built in underneath the hob and this is the number you’ve read . You will need to pull the oven out and look under the hob to find its ENR .
April 24, 2012 at 7:56 am #373438daveg1980
Doh! I do indeed, I thought it was all one unit. Based on Jazz’s analysis, is this a big job?
I will try and pull out the oven and find out.
Cheers,
DaveApril 25, 2012 at 8:53 pm #373439Jazzmeister
Not particul;arly big probably take about 20- 30 mins
Jazz
April 26, 2012 at 10:34 am #373440daveg1980
I am getting a quote around £120 mark all in, is that reasonable you reckon?
http://www.repaircare.co.uk/repair/calendar/quote
Thanks,
DaveApril 26, 2012 at 11:19 am #373441Jazzmeister
if it is just the lead you would only pay a repair fee a lot less than that, but trying to find a gas safe domestic appliance engineer is a little difficult. If you ignition unit needed replacing also then posibble to save the hassel that would be a good price…….?
Jazz
April 26, 2012 at 2:11 pm #373442daveg1980
Cheers Jazz, your a legend!
Tough call isnt it!Annoying as its not like I use the hob, but looking to rent the property out so should probably have it fixed
Cheers,
Dave -
