y video explains my problem but if it is easier, I also attach my script:->
http://uk.youtube.com/watch?v=ZoFQgyUkg8s
Several months ago my Bosch Gas hob began sparking, spontaneously, maybe once an hour when all burners were turned off.
So I cleaned all the parts thoroughly and replaced:
· the FZ4 ignition device twice (with TFZ4s),
· two ignition leads (that is the leads from ignition device to burners) and
· the wiring loom that is the 4-burner-switch-wiring connected together.
Despite this, the problem remains and has got worse because the new ignition device sparks continuously when the burners are off.
If I now connect the mains power to the ignition device – you can see it sparks continuously inside itself and if I now connect some ignition leads – the nearest burner sparks continuously. The sparking only stops if now disconnect the earth wire.
This new continuous sparking did not occur with the old FZ4 ignition device but I broke that. Two dealers assure me that the TFZ4 is the only direct replacement available but I cannot see what else the fault could be.
Any suggestions on how to fix this would appreciated
