Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off
Viewing 15 posts - 16 through 30 (of 30 total)
  • #463879
    Paul_A
    vchook wrote:Do you mind me asking where is the fuse located as I have exactly the same problem. Thanks
    Looking from the back its on the panel on the left.
    On mine it was a ceramic fuse so it was difficult to tell it was blown, so you need to either test or replace it..
    #463880
    depends on the model but most likley on the power supply panel
    vchook
    Thank you so much for the reply. A silly question, any reference on how to access to the bank panel or take the the unit out?
    #463882
    why is this integrated ?
    vchook
    My model is actually HBC86P753B and the back panel has no easy access door so I guess I have to take it off before seeing the fuse?
    #463884
    yes its inside looks like its on the filter panel (see pic)
    have had to pic one at random as you model number lacks the last 2 digits.
    you can check here yourself https://www.bosch-home.co.uk/customer-service/spare-parts-search
    vchook
    Thanks. I managed to open the back panel and I guess it’s the T8A smaller fuse that you are referring to? Thanks
    #463886
    correct check if its blown
    T stands for time delay
    you should be able to get them off ebay cheaper than bosch
    if it blows then you will need to find out why but beware when the microwave is working there are lethal voltages on some parts. they are well protected but, well you know where i am coming from
    vchook
    Thanks Dave, used a multi-meter to measure the existing fuse and confirmed that it is blown, so I am getting some spare T8A from Amazon, I will keep an eye on it and see whether it will blow again. Million thanks, much appreciated it.
    #463888
    vchook
    Just replaced the fuse and now it’s working. Thank you so much. One more question, the fuse that I’ve got it turns out to be F8A instead of T8A of the original, are there any major differences between the two types?
    #463889
    vchook
    Just read the explanation is about how fast or slow the fuse open or breaks.
    #463890
    correct T fuse are designed not to blow on items that have an inrush of current on startup F fuses dont do this
    so you may find it will blow over time so i suggest ordering the correct one so you have it if and when
    tsf
    Was really pleased to see this thread. It looks like the identical symptoms to what I am experiencing on my Bosch HBC84E653B.
    After a recent power cut, the microwave now cuts off after 2/3 seconds.
    But the only 2 fuses I can see both pass the continuity test. (On the left curcuit board after removing back panel.) –
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”1171″,”width”:”1567″,”src”:”http://52.56.111.184/fuses.jpg”}[/IMG2]
    Can you advise – am I looking in the right place?
    #463892
    they should be the correct fuses
    Nick_S
    Hi @electofix
    I have just seen this same post thread from a few years ago
    (https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/852483-bosch-hbc84e653b-combi-microwave-section-runs-for-2-seconds-before-shutting-off)
    I have a similar problem with the same model, an inbuilt Bosch HBC84E653B/04 combination microwave, grill and fan oven (about 12 years old)
    All functions (both the grill and fan oven) work apart from the microwave
    The symptom is when you hit the start button on the microwave, it starts to count down and then stops after 3 seconds with nothing heated up.
    I have checked the door safety switches and they are all OK
    I have replaced the Inverter and the Magnetron with working units
    I have checked the circuit board and replaced both fuses and the then the bank of relays
    But the problem persists
    I even found another unit on eBay and did some checks on that (also blown fuses which I replaced) and then did some major component swapping
    and the problem still persists
    I cannot find any information on the Initiation checks but see that failing after 3 seconds seems to be a common fault
    I am in a similar situation to Paul_A in that a replacement microwave costs about £700, and a combi would be more
    However that is only 1/4 of the problem as my wife wanted 4 units when they were installed 12 years ago (2 ovens, 1 combi microwave and a steamer)
    Now that the combi microwave does not work and the replacement units have a different appearance – so I would have to change all 4!!! at a stupid costs if they were to look the same and all work
    Do you know what else is checked in the initialisation? heat sensors etc that could be causing the microwave to fail?
    thanks Nick
