Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off
- This topic has 29 replies, 5 voices, and was last updated 6 years, 5 months ago by
Paul_A.
October 15, 2019 at 7:36 pm #96549
Paul_A
ParticipantI’m a first-timer here on these forums so please forgive me if I’m asking the wrong question in the wrong place 🙂
I have this Bosch HBC84E653B which is around 5 years old, but the Microwave section recently started cutting out after 2 seconds. The first indication of a problem was when the cut-out tripped in the consumer unit, and that might be a clue to the fault. The conventional oven section still works fine.
My skills are around repairing audio/tv’s though I have also done a few cookers and vacuums in my time, but have little experience with microwaves, though I do know enough to understand that many of the faults relate to the magnetron.
1 new magnetron later and the fault remains.
The unit cost around £800 new and a similar replacement now will set me back around £600.
Given that this not just a cheap throw-away appliance, and has had little use, can anyone suggest the likely cause of the problem please.
As I see it, there are 3 possible culprits, the control panel, power supply and exciter board, but if I replace all three it’s going to cost me more than a new unit!
Any suggestions would be most welcome.
October 15, 2019 at 9:56 pm #463865electrofix
Moderatorif you changed the mag its likely the inverter has gone. when the mags alone go they don’t normally blow trips they just stop working
but don’t pay bosch prices. Bosch microwaves are based on Panasonic technology so you can get things a lot cheaper
my only word of warning is your dealing with 5000v DC and that’s lethal
October 16, 2019 at 12:14 am #463866Paul_A
ParticipantMany thanks Dave..
Do you have any suggestions how I find the Panasonic equivalent to the Bosch part please..
October 16, 2019 at 8:42 am #463867electrofix
Moderatorsuggest you contact these guys on Ebay
have not got you complete Enr number but the one I looked up used part no 647895 bosch price £129.52
to find your part not go here
https://www.bosch-home.co.uk/customer-service/care-protection-and-parts/spare-partsDave
October 16, 2019 at 12:38 pm #463868Paul_A
ParticipantMany thanks dave – fingers crossed I’ll have a working microwave again..
October 18, 2019 at 11:35 am #463869Paul_A
ParticipantBack to square one I’m afraid – replaced the inverter and it’s still the same – runs for 2 seconds then stops..
So I’ve replaced the magnetron and the inverter, so can anyone suggest what I try next please..
October 18, 2019 at 11:49 am #463870electrofix
Moderatorscratching my head now
assume you have checked for blown fuses as there is normally a separate fuse for the microwave section
October 18, 2019 at 11:56 am #463871Paul_A
ParticipantYes, but the microwave does come on, then shuts off, which I wouldn’t expect with a blown fuse..
Is there a way of over-riding the control panel to force the microwave to run as I guess that’s the next item..
October 18, 2019 at 12:12 pm #463872electrofix
Moderatorshort answer to that one is no and it would not be safe
October 18, 2019 at 12:55 pm #463873electrofix
Moderatordifficult to know where to go from here. if it was door switches then I would not expect it to start
its the 2 secs that’s making me wonder. most of the time with mag and invertor problems it goes for about 10 till it fails
it has the makings of a board fault but can never be certain
there is one guy on ebay
https://www.ebay.co.uk/itm/Bosch-HBC…IAAOSwlGNdSsYwyou also need to check if the electronics comes with the panel
selling a control panel but you would need to check suitability. you quoted your Enr number as HBC84E653B but there are 2 more numbers after this and part will be different between models so you would also have to as him for his full Enr then go to the bosch website and check for compatibility
there is also a power board am not sure if it would cause this fault
bosch part site
DaveOctober 18, 2019 at 1:01 pm #463874Paul_A
ParticipantAfter you asking if I have checked the fuse, I went back and double checked and lo and behold there was a 10a fuse blown and replacing it has restored normal operation.
A bit annoying I didn’t double check first time as that would have saved me £120 in parts I didn’t need, though I guess one of the parts I replaced might have blown the fuse.
But, I now have a piece of plastic which I can’t remember where I removed it from, so is there someware I find a layout diagram to see where it goes as I can see anywhere obvious..
October 18, 2019 at 1:03 pm #463875electrofix
Moderatorsee bosch site above
also with the fuse blown its likely the inverter was at fault so unless there are cracks in the magnets or if it has a resistance leak to earth I would keep the mag
October 18, 2019 at 1:37 pm #463876Paul_A
ParticipantMany thanks again..
October 18, 2019 at 1:54 pm #463877electrofix
Moderatorno probs m8, glad you sorted it
its a nice feeling when you get something going
April 23, 2020 at 5:41 pm #463878vchook
ParticipantDo you mind me asking where is the fuse located as I have exactly the same problem. Thanks
