Bosch HBC84E653B Temperature control issue
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch HBC84E653B Temperature control issue
Viewing 1 post (of 1 total)
  • #78900
    OLLIE2806
    Fd 9002
    Hi guys
    This microwave oven won’t let you adjust the temp for the oven settings (microwave works fine) and does seem to heat when you turn the oven function on but won’t bring up the temp or change it by turning the temp switch?
    I’ve changed the little temp switch to no avail, it appears to be plugged into the main board at the front which I’m thinking must be at fault? Any one come across this before?
    Sent from my iPhone using Tapatalk
