The door handle is loose…….easy job methinks…..but how does the door split? Not a screw or release clip or latch in sight. 🙁 The BSH site shows the door in pieces so it must split somehow. I can’t see how the door hinges can be locked to lift the door off either.
Anyone know how to do it?
must admit dont know but should imagine the inner frame/cover 437703 will be held by hooks and needs to be carefully prised off. maybe even order one as its only £22 as it may break, as they do.
Did a bulb on one of these the other day, a good hour or so work including removal from housing a re-fitting. (as usual lead too short etc!)
