Does anyone have a service manual for this integrated m/wave?
I have to change the lampholder but it looks like you have to demolish the appliance to get access to it. Don’t want to remove unnecessary parts if I can avoid it.
Thanks Franz
I’m not sure you have that model number correct as it doesn’t show on the Bosch spares web site. Similar models show access via removing the wrap around cover. Check out that site yourself when you get that Enr number right. 😉
Service manuals for microwaves are rarer than rocking horse poo!
sorry , model number should have read HBC86Q65OB. By wrap around cover I take it you mean the 3 sided cover – removing that doesn’t give access , it looks like you have to remove most of the components under the top of the cover to gain access.
Franz
I think I’ve done one before. Haven’t had a chance to look at the diagram, so can’t be certain. Had me scratching my head for a while, but it was relatively straight forward. IIRC, I removed the control panel(4 or 5) screws, and then it became obvious.
