bosch hbg674bs1b/05
  • #100476
    mowerman80
    Hi all ive got this oven which is stuck on 160 degrees ,the touch control does nothing at all ,cant change the temperatures. Anyone had this before and know which part needs changing to fix it? Thank you.
    #480793
    assume you have checked for a child lock
    hebegebe
    I would check all of the data connections to the pcbs. I had several instances recently where a completely unresponsive button panel has come back to life after just removing the plugs to the pcb and reconnecting them. If it works when you’ve done that it’s just a question of tightening all the contacts. Worth a try.
    Graham
