The main oven cooling fans running permanently, I need conformation that the part number I have seen on the diagram is the correct part 613960. with thanks John
if these stats are causing the problem disconnecting 1 wire should stop the fan
I would also suspect one of the contact on the oven switches may control the fan so it runs as soon as the oven is switched on.
have no tech on these so am guessing and reading between the lines
