Bosch HBN131550B/02 oven
Viewing 15 posts - 1 through 15 (of 15 total)
  • #32259
    ChrisR
    Hi guys.
    Are the clocks on these ovens prone to failure?.
    I`ve got one that shows time but the oven wont work.
    Seems like clock but did`nt have a lot of time when on site to investigate fully………….child lock is off!!!.
    Ta.
    gegsy
    Re: Bosch HBN131550B/02 oven
    Daft request but I take it is set to “manual” 😕 😀
    ChrisR
    All it says on clock Greg is time.
    #234295
    nomadPaul
    When you say the oven doesn’t work , what does it actually do ? ( maybe that should be…. or doesn’t do ? )
    #234296
    ChrisR
    The time is visible on clock but neither oven or grill will work.
    #234297
    gegsy
    In that case I would check the temperature limiter hasn’t failed 😉
    ChrisR
    How does that work in relation to the clock Greg?.
    gegsy
    If the limiter has failed it takes the neutral feed away from the circo oven and grill
    ChrisR
    Thanks for that Greg.
    #234301
    jwd_73
    Bit of a long shot but I seem to remember this model has a magnet in the door top right side which activates a magnetic switch just under the fascia so the oven will not work with door open.
    Reason I say this is I had one once where the magnet had vanished so nothing would work.
    John
    #234302
    superfix
    jwd_73 wrote:Bit of a long shot but I seem to remember this model has a magnet in the door top right side which activates a magnetic switch just under the fascia so the oven will not work with door open.
    John
    These “professional” oven cleners, have a nasty habit of stripping the doors and mis-placing said magnet :rolls:
    This one though, AFAIK doesn’t have the reed s/w. Check the selector s/w carefully, if all you get is the cooling fan when switching on then I’m 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain thats your fault 😉
    #234303
    ChrisR
    Thanks Guys. 😀
    #234304
    ChrisR
    I checked the selector and it was like brand new same as the rest of the oven.
    I don`t think its had much use.
    #234305
    superfix
    Just try turning it to fan setting or grill, if the cooling fan runs and nothing else I’m willing to bet you the selector s/w is goosed 8)
    #234306
    ChrisR
    Ok.Thanks for that. 😀
