The temperature knob on my Bosch oven has a lot of play and I can’t set it accurately for around 30 degrees. The knob isn’t broken, it’s inside where the play is. I can’t see anything obvious broken when I pull knob off. Is this an easy part to replace myself or do I need to call engineer out? Thank you
Thanks, for your reply. It’s not in the knob that its loose, that is all quite tight. Its the shaft of the switch that is loose and has the play in it. Is that an engineer job?
gill559 wrote:Thanks, for your reply. It’s not in the knob that its loose, that is all quite tight. Its the shaft of the switch that is loose and has the play in it. Is that an engineer job?
not if you can use tools and take your time as to not get a wire wrong
