bosch HBN13M550B/01 Oven
  • #42166
    OLLIE2806
    I have the above oven that works fine / cooks fine then once the fan
    element is switched off the cooling fan cuts in for a very short blast then oven trips the electrics.
    Am i looking at the cooling fan motor? Any thouhgts would be much apprciated. Thanks.
    Ollie.
    #272590
    OLLIE2806
    Re: bosch HBN13M550B/01 Oven
    no ideas guys?
    any suggestions would be great going on the 6th jan.
    Olllie.
    #272591
    A1TEC
    You could be right, disconnect the cooling fan and try the oven.
    No trip= cooling fan fault. 😉
    John.
    #272592
    would have thought though that the cooling fan should come on during cooking and then run on after rather than only coming when the oven is turned off……
    not had the problem but obviously the cooling fan and the stat that initialises it have to be the first things to look at. Some Bosch ovens have the initial stat built in to the bulb holder and these have been known to fall apart and short out.
