Bosch HBN13N550G/03
  • #51109
    rocker
    This oven temperture knob, has to engage into a coupling that in turn connects to selector switch, this is now broken and not engaging.
    (have changed a couple of years ago) does anyone know if any other part need changing as well as the coupling, as connect have this part in stock but not the support listed.
    cheers John
    #306950
    Re: Bosch HBN13N550G/03
    Why not take a look on the BSH web site, check out the exact bits you need from the exploded drawings on there? 💡
    #306951
    nomadPaul
    No other part needed….just tell the customer not to turn the selector switch anti-clockwise past the 12 o’clock position
    #306952
    rocker
    Thanks for help gents, Nomadpaul as you confirmed I felt only the coupling was required as I have repaired some while ago. but needed comfirmation. John
