Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch HBN3550GB doesn’t heat and no fan
- This topic has 5 replies, 3 voices, and was last updated 19 years, 9 months ago by
dave j.
July 9, 2006 at 5:37 pm #19020
dave j
ParticipantNeither the oven element nor the grill heat up and the oven fan doesn’t come on either. It stopped suddenly rather than being intermittent. The light inside the oven works as do the timer and lights above the control knobs.
Anything I should be focussing on? I’m assuming it will be something like a blown fuse or faulty switch mechanism.
Thanks.
dave j
July 9, 2006 at 5:54 pm #181374gegsy
ParticipantRe: Bosch HBN3550GB doesn’t heat and no fan
Is the clock set to manual (hand symbol) rather than auto?
July 9, 2006 at 8:12 pm #181375dave j
I guess that’s the “make sure they’ve not got the timer on” question. 🙂
There is no hand symbol on the display or mentioned in the manual.
I have gone through the “turn off the timer” procedure, set the time/duration to 00:00, but that made no difference.
dave jJuly 9, 2006 at 9:32 pm #181376gegsy
dave j wrote:I guess that’s the “make sure they’ve not got the timer on” question. 🙂
How did you guess 😀 but you would be suprised how many calls we goto that have the clock set to “auto” or not set at all. You have set the clock havent you, I know you mentioned duration 00.00.
If all that is done I would suggest an engineer from the link below.
July 9, 2006 at 10:15 pm #181377dave j
gegsy wrote:
dave j wrote:
I guess that’s the “make sure they’ve not got the timer on” question. 🙂How did you guess 😀 but you would be suprised how many calls we goto that have the clock set to “auto” or not set at all.
I’ve done IT support in the past and know how frequently things like that can come up. Not plugging things in at the wall was always a good one. 🙂
Yes. The clock’s set. I even got it to run through a start/stop cycle on the timer and that all worked – apart from the heating up bit. 🙁
OK Thanks for the help.
dave j
July 10, 2006 at 7:47 am #181378Martin
dave j wrote:The light inside the oven works as do the timer and lights above the control knobs.
Here’s a clue (above) to the fault 😉
The ‘Temperature Limiter’ has shut off (thermal fuse) for some reason?
Check link below for a local engineer to look into it for you 😉
