Re: Bosch HBN56M550 Double Oven smells of paraffin
Have you done the initial ‘Burn’ as described in the instruction manual?
The elements (and oxylytic liners if fitted) are covered in a laquer when maufactured to protect them from atmospheric moisture ingresion.
If you haven’t done the ‘Burn’ then the laquer will still be present and will give the smell described, you may also have a little bit of smoke.
If you are unsure of the process in the manual, then give BSH appliance care a call on 08705 678910 and ask to speak to someone in product advice.
Hope this helps 🙂
Steve
