Bosch HBN56M560B/01 lower oven overheating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch HBN56M560B/01 lower oven overheating
Viewing 1 post (of 1 total)
  • #73889
    Simon46
    Been to this one and lower oven wont stop heating.If the oven is set to 100 degrees and the control is turned up quickly and the info button pressed you can see the actual temperature reading is 185 and climbing ie the info button will only show the actual temperature if it is below the target temperature never above the target. Yet the bars on the lower part of the display that show it is ready to cook dont reach full. thermistor reading matches the top oven cold so not the probe. Its as if the elements dont switch off. 3 pcbs on this one so want to get it right. My suspicion is PC board power plate complete 499014. Any one had a fault similar on this type of oven? 😕
    Regards
    S.
