I have just received my replacement element from UKWG and now need to fit it. Having not worked on an oven before, is it straight-forward? Do I go in from the front or the back? Am I likely to run into any problems? What are the steps I need to follow?
Half moon element. Turn off power and remove door. Remove cover panel in the back of the oven cavity. Remove oven fan (Note: Nut is left hand thread). Undo the five screws to release the element, swap the wires and off you go.
