Bosch HCE422120V/09 convection oven tripping earth detect on panel.
Home Forums Public Support Forums International Forums European Appliance Forum Bosch HCE422120V/09 convection oven tripping earth detect on panel.
  • #96008
    alan0847
    The above trips when oven is on top element only or both elements. Does not trip on bottom element only. I have replaced the top element twice with 2 new elements but does not fix the problem. Thermostat functions properly on bottom element but trips panel when it operates on top element. Top elements heat up without problem until board is tripped by thermostat cutting in. Any suggestions, is it the selector switch?
    #462047
    alan0847 wrote: Top elements heat up without problem until board is tripped by thermostat cutting in.
    assume you mean thermostat cuts out when it get up to temperature
    where did you get the element from?
    is it a genuine element or a copy
    this fault does still sound like an element fault. If it was the switch or controls it would not need to get hot before it trip. I am assuming that while its cold you can turn the thermostat on and off without it tripping
    alan0847
    Thanks for the reply Dave, I have both, one is a copy and the other is original. I have a third one which is a copy, I’ll give it a try.
    thanks Alan
    #462049
    alan0847
    I’ve just been checking the small print on the elements which is very difficult to read. The original element is rated at 400v and the new ones only 240v. That’s probably the problem don’t you think?
    #462050
    alan0847 wrote:I’ve just been checking the small print on the elements which is very difficult to read. The original element is rated at 400v and the new ones only 240v. That’s probably the problem don’t you think?
    no that’s not a problem. the only place you will get 400v is in a factory and the oven is not built for it
    alan0847
    I’m in. Sweden, the oven is rated for 240/400v and has a 3 phase connection.
    Ive got it on at the moment and it seems to be working ok at 200c. It wouldn’t stay on yesterday. I’m wondering if it was the damp in the element problem that I read about. I’ll let you know if it’s starts to trip again.
    Alan
    #462052
    does sound like damp the way its reacting
    as the damp gets driven out unit can trip. as damp get less unit stays on longer till all being well its ok
    if oven is operated on 3 phase then elements will be equally split between phases but elements still operate on 240v. if you put element on 400 v you would double its output to 4kw and things would seriously overheat
    alan0847
    Oven is working ok because top elements have stopped working, I’ve ordered a 400v element here in Sweden. Thanks for your help i’ll let you know how I get on. These elements are expensive near £100.
    Alan
    #462054
    alan0847
    Received and fitted 400v element, now working ok.
    Alan
