Bosch Heat pump Dryer WTW84560GB/11
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Heat pump Dryer WTW84560GB/11
  • #93402
    M1
    Not getting HOT
    No fault codes or lights flashing on screen, any ideas this is the first one I have looked at.
    HEAT PUMP dryer
    #454227
    Re: Bosch Heat pump Dryer WTW84560GB/11
    if its the first heat pump dryer you have looked at you have to understand how they work. not that I doubt your knowledge but you have to think a different way
    a normal dryer heats the air with an element, this evaporates the water, and the condenser that’s cooled with air from the room takes the saturated air and condenses it out
    now a heat pump dryer has no heater so in effect its a de-humidifier in a box. the air is blown around the case across the clothes, This air is passed through a cooled heat exchanger (evaporator) so it forms condensation and reduces the humidity of the air this then passed through the condenser of the system and flows back to the clothes. the only heat in the system is waste heat from the compressor
    so in essence they don’t get very hot at all, more like slightly lukewarm
    you need to find out if the compressor is running and check all the filters
    M1
    Yep
    I have read up on them and yes the compressor is getting lukewarm. I shall check for blockages and filters.
    #454229
    smartin
    The other important thing is that it takes about 15 mins before any heat can be felt inside.
