Bosch Heat pump ohms reading diagram please?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Heat pump ohms reading diagram please?
  • #83605
    MANDELLS
    Guys I’m sure I’ve seen it on the forums before, but could somebody be so polite as to post a link so that I could check the readings on a Bosch heat pump, thanks in advance
    #423238
    clivejameson
    Re: Bosch Heat pump ohms reading diagram please?
    I haven’t got a link but they are much the same as any other wash pump…two windings with similar resistance (three differently coloured wires next to each other on the connector block). The heater part can be identified by the two wires with the same colour and give a typical heater reading ~20ohms
    #423239
    MANDELLS
    Hiya Clive, thanks for the reply BUT I’m on about a diagram I see on here a few weeks back, I’m on about the new heat pumps too the ones that have small connector blocks, plus the diagram had the readings for the motor too. Cheers
    #423240
    clivejameson
    Yes…thats the one…just this min attended one with a failed heat pump, or at least the heater has failed. Three thinner grey wires for the pump unit and two red for the heater…plus an earth of course.
    There are two types of connector block but IIRC the earlier ones come with a wiring mod for the newer connector block…
