Bosch heatpumps failing on install,is it just me??
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch heatpumps failing on install,is it just me??
  • #93473
    MANDELLS
    Morning guys im having a load of recalls on these pieces of shxt, (5 in the last month) some even failing on install, is there any advice on how to explain to customers that there is DEFINITELY a major problem with them, have bosch rectified the problem or shall i just refuse to fit them from now on
    Your thoughts please
    #454446
    Re: Bosch heatpumps failing on install,is it just me??
    assume you let them settle after install before you turned them on
    since they are under warranty did bosch say anything when they were called out ?
    MANDELLS
    Hiya dave, once i fitted the pump it worked 5 times, when you say about leaving it to settle do you mean if as though its been in the van and cold or something,?
    Ive got absolutely no faith in thes machines
    #454448
    its effectively a fridge so if you tilt it or transport it needs time for the oil to settle before you turn it on
    I was thinking of the new ones failing immediately
    not seem many of these machines yet but the ones I have seem to work ok. with your luck I would forget winning the lottery lol
    MANDELLS
    Oh dave, wires crossed mate, (my fault) i ment the heatpumps on the dishwashers,
    #454450
    ah see what you mean now lol
    seen a few of these fail as the heater unit is quite flimsy. you can see a picture I posted of the heater unit here
    bosch-dishwasher-heat-pump-failed-prematurely-t96258.html
    if these units were ultra unreliable I think Bosch Neff engineers would be going hairless with Under guarantee repairs but its also worth noting that whirlpool have a mod kit to change it back on their dishwashers
    you say these pump are failing on install, I now assume you mean you are replacing the unit in the customers own unit out of warranty. these heaters will blow very easily if overheated. so can blow through lack of water flow which can be all the normal suspects. Blocked bars, broken diverter, too much foam and blocked filters. It is all in all a very poor design as the normal flow through heater is much more reliable
    Rumoured that sales of decent ‘syrups’ ( cockney rhyming slang) are at an all time high amongst their ranks.
    TBH it won’t really worry them, it’s the Indies who fit them out of warranty who will be suffering. 🙁
    #454452
    assuming they are not earthing due to leaks? the heater part of the pump sits below base level so a little bit of water will get straight in there. Yes I get loads of repeated failures but not usually on install. Usual reasons are the water hardness not being set correctly if its a hard water area or lack of salt (no doubt all freshly topped up just before we arrive) or lack of filter cleaning (no doubt all freshly cleaned just before we arrive).
    #454453
    would be nice to get an idea if its hard water areas where these fail more often
    grooster
    I’m in a very soft water area, North West England and can honestly say I’ve never been back to one i’ve fitted. I have had quite a few heaters go o/s over the last few years on these heat pumps but of all the ones i’ve fit, ive never been back. So you may be right, it may be a hard water issue.
    #454455
    aqualectric
    I live in a hard water area (Dorset) and I have only had one customer that I can recall that has repeated heat pump failures. His dishwasher is just four years old. I had to fit a new heatpump within the first year despite his warranty as he couldn’t and wouldn’t look for his paperwork and wouldn’t wait for BSH to do it. I have not altered the hard water settings on any of the heatpump machines I’ve repaired.
    But…….
    Blocked filters, blocked wash rotor jets, filters not locked down properly and impaired wash pump paddle capacity due to it being full of cr@p that can only get there if the filters are not clean and locked down.
    So the bottom line of the fault flow chart is the lazy arse user. The absolute irony is the customer that I mentioned at the top of this post who will not get to grips with cleaning his filter for months and doesn’t lock it down has just been visited today and a new heatpump is on order. Fourth time lucky, eh? :bang:
    I shouldn’t care really because I get paid every time…….
    Steve.
    #454456
    alster
    Fitted one to a Siemens last week and in with the pump was a new plastic baffle that clips into the sump by the pump inlet. Looked the same as the old one but wondered if its to help water flow.
    #454457
    Good info but Dorset doesn’t even make the top 20 hard water areas. Lawrence Carey is in #1 position.
    https://www.mirror.co.uk/news/uk-news/h … n-11076004
