Evening all
Hope someone can give some guidance regarding an issue I have.
I have a Bosch five burner gas hob.
I was heating up a pan of water on the main large wok burner when some of the water from the pan started to leak out due to the handle on the pan breaking – the water escaped from one of the rivet holes which attached the handle to the pan. Anyway, a fair amount of water leaked into the burner.
I turned off the burner and thoroughly cleaned out all visible water but now the burner won’t work.
I can smell gas but it won’t ignite.
Is it simply a case of waiting for the burner to dry out thoroughly or will it inevitably require an appropriate engineer to investigate.
I can provide details of the exact model number tomorrow if necessary.
TIA.
