bosch integrated 9000405865 en 640EV flashing brush or tap
Home Forums Public Support Forums Help And Support Dishwasher Help Forum bosch integrated 9000405865 en 640EV flashing brush or tap
  • #91810
    ollski
    Hi got this integrated washer which I usually use on 70 deg wash, if I try now it will begin whirring a few times and then stop with no water seeming to go into the machine, then it will error with sometimes the brush and end symbols and sometimes the tap and end. I turned it to the 60 deg wash the other day and it worked once and I put it on the rinse cycle today and it worked.
    Is the water supply opened by a pressure switch? and if so is there something somewhere I should be cleaning or checking in the appliance?. Many Thanks
    #449360
    ollski
    Re: bosch integrated 9000405865 en 640EV flashing brush or t
    No ideas?it seems to be driving a pump but no water supply, is there any way to bypass this pressure device at the water inlet hose?
    #449361
    No ideas because you didn’t supply the correct model number (ENr number) for us to know what machine you refer to?
    #449362
    ollski
    sorry, took the number off the manual, on the data badge its a SMV50E00GB / 16
    #449363
    The flow meter could be sticking (located on the metering tank on the L H side) or may just simply be a blocked flow filter on the water inlet valve (aka aquastop)
    #449364
    ollski
    I’ve cleaned the filter to no avail, but yesterday I removed the waste pipe from the macerator connection and ran it into a bucket and it completed 2 washes although the fill noise sounded different to normal. The waste was clean so I’m not sure why the difference or maybe just coincidence.
