Bosch integrated condenser dryer WTE6920
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch integrated condenser dryer WTE6920
  • #30478
    nelson
    Hiya,
    I called out to this dryer today, fault is, customer sets it to cottons cupboard dry, display shows 82 mins, runs perfectly for 5 or 6 minutes then display fogs up and jumps to 0 mins. I thought it might be blocked up not condensing thus steam escaping into display, but filter and condenser unit spotless looked as new. I did notice that there wasn’t any moisture on the condenser unit?! I really cant work this one out as everything looks ok. Can anyone suggest anything I might be missing.
    Cheers 😕
    #227348
    gegsy
    Re: Bosch integrated condenser dryer WTE6920
    Well its steam from somewhere 😕
    Have you checked teh uplift pump assembly from start to finish for obstruction?
    If the drawer is used, where the hose enters the dispenser (top rear), remove and look for any lint blockage.
    Remove uplift pump as Ive seen a ball off fluff jam the poor impeller 😉
    Look also if condenser fan (not heater fan) is working indeed and temperature sensor aswell.
    #227350
    superfix
    It has an interior lamp, make sure the cover hasn’t gone missing 😉
    They have a habit of going brittle and the legs snap off.
    #227351
    nelson
    Thanks fellas, sorry I’ve been out of commision for a few days, so I’ll try your suggestions.
    Cheers
    #227352
    Kentish
    What about moisture shorting the sensor wires at the heater plug where it comes thorugh the cabinet?
