BOSCH Integrated D/W
Mod – SGI45E15GB/23
Machine will attempt to start the programme but doesn’t recognise when it is full of water. It simply continues to fill, activates the mushroom shaped overflow located inside near the filters, which in turn runs the empty pump for a few seconds. The check water light LED is lit
I have replaced both the ‘water inlet impeller jug wheel’ and fitted/programmed a new Module, the fault remains.
Any ideas what else might be causing such a fault, i have ensured that the connection terminals are not causing a problem, they are nice and tight…
All help and suggestions greatly appreciated and welcomed..
Many thanks
