Bosch integrated dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch integrated dishwasher
  • #79069
    brambles123
    I was hoping someone would be able to help me. We’ve been living in our house for almost a year and until now had no problems with the existing Bosch integrated dishwasher.
    However since Christmas it’s been fusing and we’ve had to keep turning the main panel on the fuse back off and on again.
    It smelt slightly of burning. We did find a few scraps of food so thought it may be blocked however we’ve had a look and it doesn’t appear to be.
    I’ve read a few forums and people say it could be the heating element? It is a certain point in the cycle when it just cuts off.
    However I’ve no idea what model we’ve got, it’s white at the sides and silver. The top shelf height can be adjusted and the bottom one can roll out. Here’s a photo: http://i41.tinypic.com/35irner.jpg
    How would we check and fix this?
    Any advice would be greatly appreciated
    Thank you
    #407791
    Re: Bosch integrated dishwasher
    Power disconnected, pull it out and remove side panels. Heater and motor located behind the right panel, water inlet system behind the left. You will need an insulation tester in order to check out what component is causing the earth trip.
