Dishwasher not working, all LEDs dead. There is water in the bottom of the compartment, if I empty it out with a cup it refills and then the float valve shuts it off, so there is electrics to some parts.
I have studied similar topics on this forum and have checked the door switch – all OK. Then examined the PCB, no signs of damage or any burn marks. I removed the Main Switch on the control panel and checked the terminals for continuity :- there are six pins, I found that there was only continuity between pins 1 and 2, also 3 and 4, but nothing between 5 and 6 – could this be the problem ?
I would much appreciate any advice on this or whatever else the cause could be.
Thanks Ian
