Bosch integrated fridge freezer replacement problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch integrated fridge freezer replacement problem
  • #77992
    Mark D
    I have a Bosch fridges freezer from 1998 which has stopped working. A Bosch engineer has visited and told me that the insulation has gone and that the appliance needs to be replaced. I have spent hours at various shops and online trying to work out the appropriate replacement model but can’t work it out. I am concerned to make sure that the existing door panels can be used on the new appliance. The existing fridge freezer is model no KIM3002GB/32, FD7803. It seems to look like what are described as 70/30 models, but the 70/30 models appear to have slightly different dimensions. It’s going to break the bank to buy the new appliance and I can’t afford to have new doors made!
    Can anyone help please? Many thanks in advance.
    Mark
    #404110
    don
    Re: Bosch integrated fridge freezer replacement problem
    Hi Mark
    Have come across this a few times lately. If you have the slider hinge set up measure from the bottom of the freezer decor door to the top of the freezer door itself and from the top of the fridge decor door to the bottom of the fridge door itself.
    Hopefully with these measurements you will be able to adjust the height of the decor doors on the new appliance even if the split may not be exact as your current mnachine.
    HTH 🙂
    Don
    #404111
    jeba
    I have the same problem of having difficulty in replacing Bosch f/f. Did you find a suitable fridge freezer without having to replace doors?
