need some advice please, recently replaced thr element in my oven but i now find when the oven heats up there is a vibrating noise coming from the fan/element section,is it fixable 🙂 I do hope so 😕
I’m guessing this may be the half moon element on the under counter double oven ? If it is , how did you access the screw behind the fan blade ? If its not this model , then i’d still check that the fan blade is on properly
