Bosch integrated smv50c00gb not drying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch integrated smv50c00gb not drying
  • #84933
    karlosfandango
    Hi all,
    I’ve had a look on t’interweb for my problem and it would seem that my heating element has packed up.
    I have a 3 (ish?) year old integrated Bosch smv50c00gb dishwasher which has been great until yesterday.
    We woke up to find we’d had a power cut. On further inspection the RCD had tripped. When we later tried to use the dishwasher, that wasn’t working. Checked everything and found the fuse had blown on the plug. Changed it and, wahey, all back up and running……or so I thought
    Now it’s not drying, and if i open mid cycle the water isn’t hot. Yep, my powers of deduction lead me to believe it’s something to do with the heating element!!
    My question is this……
    Is it like to be anything else before I attempt to fix it myself?
    Is it fairly easily fixable for a ‘handy’ DIYer?
    I’m seeing £130 ish. Is that about right?
    Ok, so that’s actually three questions, but I know you’re all up to it!!
    Thanks in advance
    K
    #427193
    Allsorts
    Re: Bosch integrated smv50c00gb not drying
    Is it heating during the wash?
    #427194
    karlosfandango
    Thanks for the reply Allsorts. No, it doesn’t seem to be.
    #427195
    Allsorts
    Then the problem you have will be with the Heat Pump
    #427196
    karlosfandango
    Ok. Is that easy enough to fix myself? I’m pretty good at that sort of thing normally and have done stuff like that before. This thing?
    http://www.buyspares.co.uk/dishwasher/s … ef=1228120
    thanks again for your continuing help
    #427197
    Allsorts
    If that is the right model then look at this supplied by bosch
    http://www.bosch-home.co.uk/store/product/Heatpump/00651956
