Customer is complaining that on dry cycle the time is set and will count down and then go back up to the same time hence drying forever. Heat is found in clothes. Any ideas before i go and look at it?
Re: Bosch integrated Washer dryer time problem WET2820GB/13
Simon,
3 things to check in this case that can lead to dryer errors, Firstly the condenser ducting getting blocked at the bottom by the hose connection to the tub. Or, the quad valve open circuit(no water flow) and finally the TOC tripping 😉
