bosch interlock – 182154 / 603514 interchangeable?
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts bosch interlock – 182154 / 603514 interchangeable?
  • #76717
    gandh1
    got a WFL2462 (gb/xx unknown ’til i get there as cust says its faded away) with no a no start fault to see tomoro evening. just checked my spareslist and got a 603514 in the box, and qualtex seem to list both. just wanted to know if it isnt exactly the same (lookin at the pics, one is the clip fit and the other is a screw fitting), is it still tagged the same way, so if isnt the same one, i can still dismiss the fault being the interlock if the fault persists, and if it does work, order the other one if needs be, or just leave it on if works and its perfectly interchangeable, and save myself a recall to fit 🙂
    #399543
    Re: bosch interlock – 182154 / 603514 interchangeable?
    You will need an 00182154 or a 00171256 interlock for that beast.
    #399544
    seem to recall trying to fit a screw on one in place of a clip in and for some reason it would not fit, cannot remember why.
    #399545
    gandh1
    Martin wrote:You will need an 00182154 or a 00171256 interlock for that beast.
    martin, is that because internally its different to a 603514 tho? or is the only difference the clip fitting?
    anyways, seems fault isnt that it wont start, it wont turn on at all, so presuming thats pcb as main power feed goes directly into back of pcb, yet theres continuity all way from plug pins to pcb terminal, so not suppressor or lead…
    #399546
    It may well be the interlock has blown the PCB and only close inspection of the board could confirm that. I personally wouldn’t mess around trying to fit the wrong type of interlock by the way.
