bosch KAN58A40GB/07 freezer not freezing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch KAN58A40GB/07 freezer not freezing
  • #60222
    slyp98
    hello again moe fridge probs , this bosch american style f/f has developed this problem of not freezing the display reads – 18 but it aint that inside, more like +3 also does anyone have a technical sheet or a diagnostics guide for these models thanks much
    #341234
    nomadPaul
    is it the whole of the freezer section that isn’t cold or is it more towards the top if the compartment ?
    I have had to change a few good freezer fans on these models for ‘warm’ freezers – part no: 601067
    #341235
    slyp98
    Re: bosch KAN58A40GB/07 freezer not freezing
    i’m 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure it was all through the compartment , in fact its colder at the top of the compartment just checked with the customer
    #341236
    TeeMyob
    Fans know to fail but thermistor is reading temp as okay. What does the display read if you switch it off an back on at the mains?
    TM
    #341237
    slyp98
    same as before it was turned off , -18 freezer 4 fridge , fan works fine had a look around the back , i take it this is the fan you are talking about ? or is there another in the evaporator , i took off the freezer interior panel to expose the evaporator and there is a block of ice at the top of the evap coils so i’ll let it defrost for 36 hours and see if that helps
    #341238
    slyp98
    ok so no change , freezer is now on -21 and its cold ,but its not -21 definitely colder at the bottom than the top and the evap fan is not kicking in anyone know when and how often the evap fan runs for i tried to get a continuity reading from the fan wires but i got nothing same as when the meter was idle
    #341239
    slyp98
    i ordered the evap fan motor 10 days ago , just got it yesterday fitted and working well now thanks guys
