Bosch KGE3265 Fridge Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch KGE3265 Fridge Freezer
  • #31936
    matty123
    After turning the fridge freezer on after a while when it wasn’t used, it did not pull the temperature down in the fridge or freezer compartments, which remain at ambient, even when the ‘super’ buttons are pressed. I can hear the compressor running, and gurgling from the coolant, but zero cooling. Any ideas, it worked perfectly before?
    #233004
    Re: Bosch KGE3265 Fridge Freezer
    Presumably it’s lost the coolant during the lay-up. A re-gas may get it going again, but this is futile if the leak is not found.
    System work is definitely a job for the pros – use the repairs@ link below for an engineer in your area.
