Bosch KGN34V00 GB06
  • #68883
    Profyaffle
    Is there a Configuration of pressing buttons that puts on the defrost heater with this model? Any help would be appreciated. Chris
    #373064
    nomadPaul
    Re: Bosch KGN34V00 GB06
    Switch off from control panel . Hold down super freeze and switch on . Hold the super button down for approx 5 seconds until -16*c led flashes – you are now in the test programme . Pressing the temp select button will move through the different tests . Pressing the super freeze button starts the test .
    If i remember correctly…….
    -16 – sensors
    -18 – freezer fan
    -20 – defrost heater
    -22 – compressor
    Switching off will terminate test programme .
    If current draw for heater is around 0.75 amps then its normally ok . If its 0amps then possible open circuit heater but don’t forget there is a thermal fuse on the evaporator that is in series with the heater .
    #373065
    Profyaffle
    Thanks Paul. I had this one stripped out today and nearly died of fright. Poor young lady bought it in August 2007, had a visit out in April 2008 by an engineer from a Large electrical retailer who said it needed 4 things. PCB, Plate, Mod Kit for the drain hole and fan.
    Came back to it and only fitted the fan.
    Return visit shortly before Warranty expires and customer informed to just defrost.
    3 years later she calls retailer on a chargeable job and the Engineer writes on the Job sheet that her FF needs the other 3 parts……mmmmmmm???? I, as I said stripped it out and there were no other parts fitted. Should they be the same parts as per KGN33?
