bosch KGU31123GB/05
Viewing 1 post (of 1 total)
  • #79850
    rickard
    Went to this fridge freezer for a complaint of the fridge will cut out and stay out unless you select super or switch it off and back on again. I suspect the sensor like the older bosch f/f with the foamed in sensor, when I looked for a part I came up with 172761 This came with a sensor, tags and a plastic cover which I presume you have to cut out the sensor and the cover is to cover the hole up. The problem is where to cut out for the sensor or am I barking up the wrong tree and you cant replace the sensor, if so would a new board sort this out. Any help would be appreciated
    Andy
