Bosch KGU3201GB/05 – error E1
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch KGU3201GB/05 – error E1
  • #42425
    trevordh
    With the help of this forum I’ve found that the E1 error is caused by the failure of the internal fridge sensor. (The fridge contents were frozen, which was probably a big clue)
    The Bosch spare parts dept can’t tell me which sensor I need (there are two listed) nor is it obvious how to change it.
    The only sensor I can find is located in the left wall of the fridge, in a covered clip-in recess. I presume this is the one to be changed? But how? The cable just disappears into the wall of the fridge.
    Any advice would be gratefuly received. Thank you.
    #273465
    trevordh
    Re: Bosch KGU3201GB/05 – error E1
    I gave the sensor a good clean and the fridge has behaved itself since.
